      04-02-2024, 09:00 PM   #1
gcbm5
Drives: 2013 m5
F10 m5 drag racing
Hey guys! Looking to get some advice on drag racing these cars. I have a 13 m5 with stage 2 e30 tune and 305 19inch Mickey Thompson ETS. Been having trouble getting a good launch. Trying to get the best quarter time and looking for any advice on best launch procedure/ tips. Thanks!
      04-04-2024, 10:10 AM   #2
KurtsM5
2013 F10 M5  [9.25]
Why 19"? I'd try some 315s. on 20" rims. Do you use MDM mode?
      04-04-2024, 08:37 PM   #3
gcbm5
Drives: 2013 m5
That’s a good idea and I was thinking to give a little more sidewall. No just traction all the way off using launch control. Been playing with xhp
      04-06-2024, 01:29 AM   #4
SmokinJoe
SmokinJoe's Avatar
44
Drives: 2014 M5 CP, 2019 X5 40i
If you have bm3 you can do boost by gear. May help with traction in 1st and 2nd gear.
      04-06-2024, 10:14 AM   #5
TrueNorthM5
Drives: 2015 Alpine White BMW M3 (DCT)
Yea launching these cars is not easy. Also be careful of the diff! I get wheel hop often. My best is 11.3@126 on Cup2R's with a stage 1 93 tune, but my 60ft is still terrible (1.8-1.9). This is using launch control with warm tires launching around ~2800rpm on a street surface.
Currently: '15 M5 (dct) BM3 STG1 11.3@128 Spinning /// '11 X3 35i 13.9@99/// '02 Transam 12.7@112
Previously: '15 M3 (dct) BM3 11.58@126 /// '13 Cadillac CTS-V 11.9@115 /// '12 128i /// '08 Benz c300 6spd
      04-06-2024, 01:54 PM   #6
gcbm5
Drives: 2013 m5
Yeah I do and I’m thinking that would be good to pull back some boost so I can really hook up nice because this thing has so much down low that is wasted. Just gotta get it just right!
      04-06-2024, 01:55 PM   #7
gcbm5
Drives: 2013 m5
Yeah it’s definitely not easy! That’s really solid on stage 1! I’m running stage 2 e30 blend and Mickey Thompson et streets so hopefully on the drag strip being prepped I can really get some good hook ups. I heard about that as well and needing upgraded cv axles. 2,800 nice spot to launch it at?
      04-06-2024, 11:06 PM   #8
TrueNorthM5
If all else fails you can try launching off essentially idle without launching control. Feather the throttle for half a second before laying down the full hammer. It's worth practicing before going to the track. I know that once the rears start to spin, it only gets worse unless you shift early and bog the engine or let off. In my case best times were with launch control but it wasn't easy to get everything right.
      04-07-2024, 04:24 AM   #9
KurtsM5
2013 F10 M5  [9.25]
If you're going to beat it hard on the drag strip you might want to do this-
https://www.rkautowerks.com/index.ph...et-diff-mount/
      04-07-2024, 01:51 PM   #10
gcbm5
Drives: 2013 m5
Yeah that makes sense and I’m going to play with it this week before next weekend when I go to the strip. I also agree with xhp and dialing it in the best times are achieved when using the launch control.
      04-08-2024, 02:54 PM   #11
gcbm5
Drives: 2013 m5
Yeah I heard those are good but expensive lol
KurtsM547.00
      04-10-2024, 06:34 AM   #12
KurtsM5
2013 F10 M5  [9.25]
Ridiculously expensive...
      04-12-2024, 01:37 AM   #13
SCD-1983
SCD-1983's Avatar
True, but way less expensive than destroying your driveshafts and other components. I will install the billet diff mount shortly, as it’s a known weak spot in the overall drivetrain.
KurtsM547.00
      04-12-2024, 08:16 AM   #14
gcbm5
Drives: 2013 m5
Yeah that’s a good point! I’ll be getting one soon after I save up some more in the m5 parts fund lol
