      10-08-2024, 09:45 AM   #1
anoller
Drives: F10 M5, F10 535i, Duramax, etc
So, I am reaching out to the interwebian-forums for some help. 2 garages have told me it is a VANOS cam gear failure and my issue requires an insane amount of work (ie: cam gears/sprockets and timing chains) The car is a 2013 M5.
I am getting the following codes:
131401 - “Variable camshaft timing control (VANOS), exhaust, cold start not controllable”
120408 - “Charging pressure control: Switch-off as consequence”
120908 - “Charging pressure control 2: Switch-off as consequence”
These trip within the first 30 seconds of the car being started “cold.” The idle increases to 2000rpm and hunts around as the VANOS system looks for its adjustment. (Escentric shaft motor tested and gets to its limits). The car then settles down into an awful idle, and stays running although a little “high.” After letting the car warm up, oil get to temperature, you can shut down the car, clear the codes out of the system, and then restart and it’s 100% happy and fine. Pulls like a freight-train and is happy. So it’s a cold-start issue. Weird right? So, before tearing into an engine and spending 8-10k on it, does ANYONE have any idea as to the problem?
New VANOS solenoids
New spark plugs
New coils
Engine flushed 3x liquid moly
      10-08-2024, 10:50 AM   #2
Hey wassup, always worth looking the 2 pre cat and 2 post cat lambda sensors with suspicion and of course if the MAF's are oil free before going deeper.
KurtsM5909.00
anoller15.50
M5_Raz852.00
      10-10-2024, 08:29 AM   #3
anoller
Wouldn’t they trip a code?
M5Rick90415.00
      10-10-2024, 12:59 PM   #4
Even if they don't it would be worth swapping round the sensors to see if there is any difference, I'm bringing up a previous thread with similar cold start problems as yours even though codes are different.
      10-10-2024, 09:24 PM   #5
anoller
Similiar cold start problems? Interesting. I will just pop in a few new O2 sensors and see what that does. Man… if this actually fixed it, hooooooly craptards.
M5Rick90415.00
      10-11-2024, 03:04 AM   #6
GL but if no then I don't know what to suggest, I gather car is not tuned.
      10-11-2024, 10:04 AM   #7
E36graduate
E36graduate's Avatar
73
Drives: 2013 335i M-Sport 6MT
Too bad you cannot bypass the cold start high RPM with a tune of some sort like BM3?
2008 335xi - 6MT - BMS JB4 G5i - BMS DCI - BMS OCC - BMS WW Meth - Spec Stage 2+ - Spec SMFW - 19" MVR Magnum's - KW V1's - TMS 12.5+20mm Spacers
anoller15.50
      10-13-2024, 04:23 PM   #8
Solo_M_Tech
Solo_M_Tech's Avatar
Drives: 2014 M5 6MT
2014 BMW M5  [0.00]
You probably have a failed vanos adjuster ( the part bolted to the end of the camshaft). It’s rare, but not impossible. They have tiny oil passages that get clogged with debris and then are slow to respond to oil pressure changes ( at the command of the solenoid) or fail to adjust at all. Generally speaking it’s usually contaminated by bearing material, that causes the adjuster to mechanically act sluggish. Drain the oil through a paint screen and check the filter for glitter. Post pics or oil condition and filter.
2014 M5 6MT
anoller15.50
      10-22-2024, 06:54 AM   #9
anoller
I wish there was a way to back-flush the engine’s oil passages. And the failed banks adjuster is 95% the culprit. I’ve seen where the bolts holding the adjuster can fail (N55’s, but we have the same VANOS setup in the S63TU). The VANOS adjuster is a bit more than I’m wanting to tackle at the moment as ‘time’ is a scarce commodity. Searching for a spot where they’re skilled in S63 timing, etc. Judging by the handle, I suspect it’s Solo Motorsports?
      10-22-2024, 06:55 AM   #10
anoller
Not tuned.
M5Rick90415.00
      05-30-2025, 06:36 PM   #11
SahandBB
SahandBB's Avatar
Drives: Bmw M5 F90
Did you find out what was wrong with your car ? Running to the same problem exactly now
      05-31-2025, 05:22 AM   #12
KurtsM5
2013 F10 M5  [8.80]
Solo in Lawrenceville worked on mine a couple years ago, they're good.
