| 02-07-2012, 04:16 PM | #1 |
Rep 693
Any M5 owners see idrive option to disable in cabin active sound function?
Someone speculated in another thread that there might be an option in the new m5 idrive that allows you to disable the active in-car soundtrack feature. Any owners out there that can confirm or deny this?
| 02-07-2012, 06:50 PM | #2 | |
Rep 1,440
- Frozen Grey F10 M5 DCT
- Rosso Corsa 458 Speciale Sold - Frozen Grey E92 M3 Sold |
| 02-07-2012, 07:23 PM | #3 |
![]() 160
Rep 3,521
I speculated and I bet it is a hidden screen option.
Very few M5's out there but I am sure someone will find a way to get into the dealer programming screens... |
| 02-09-2012, 04:09 PM | #7 |
Rep 10,187
Yes, it works with radio on or off
| 02-09-2012, 08:29 PM | #8 | |
![]() 9
Rep 139
Here's the Automobile article that explains the Active Sound, and what fuse you need to pull to eliminate it. It's the amplifier fuse #200 rated at 40 amps. If you eliminate the active sound, you lose the entire audio system. |
| 02-13-2012, 01:27 PM | #9 | ||
Rep 693
| 02-14-2012, 09:50 AM | #10 |
![]() 9
Rep 139
That's got to be ridiculous. I'm sure the aftermarket people will come up with a fix, although it might have to involve an ECU reflash.
| 02-15-2012, 05:57 PM | #11 |
Rep 4,567
If the M5 was somehow amplifying the actual sound of the engine in real time through the speakers, though would be one thing (I'd still think it was silly). But the fact that it's playing a pre-recorded sound file of the M5 doing a dyno run is utterly ridiculous.
I'm sure tuners will be able to flash this off.
'09 E92 M3: Space Gray, Black, Carbon Leather | ZTP 2MK ZPP 2MT 6FL | link 1 / link 2
Mods: M Performance exhaust | ZCP retrofit | Euro airbox | GTS DCT flash | JPN 240 ECU flash | Euro LCI taillights | CRT lip | OEM alarm retrofit | Space Gray bumper plugs | BMW Performance: Mk. II spoiler / Mk. II non-electronic steering wheel / mirror caps / front grilles / side gills / intake louvers / emblem |
| 02-16-2012, 04:14 PM | #12 |
Rep 10,187
Its a completely independent system that generates and feeds the sound into the sound system. No ECU flash will disable this.
Maybe unplugging the control box, but this may bring up errors. There are actually 2 different versions of the system depending on which sound system you have The car is supposed to be way too quite inside without it
| Bookmarks |
